Front subframe to body mounting https://www.ausmini.com/forums/viewtopic.php?f=2&t=67511 |
Author: | mtsmini [ Mon Dec 06, 2010 10:45 pm ] |
Post subject: | Front subframe to body mounting |
Am I correct in saying that the subframe (twin bolts on each tower) mounts directly to the body with nothing between the body and the subframe? No rubber or polybushes between body and subframe? I can't recall what I took off it was so long ago!! ![]() |
Author: | willy [ Mon Dec 06, 2010 11:21 pm ] |
Some Mini's I have disassembled have had metal plates, others have had none. I think I put it down to the Leylands having plates rather than Morrises. But I am also known to be wrong at times. Someone will put the correct answer up soon! ![]() |
Author: | GT mowog [ Tue Dec 07, 2010 6:58 am ] |
The Ozzy Dry Subframes have a spacer about 1/4" thick . In shape it is similar to the lock plate that goes on top of the bulkhead. I'll try and get a pic up later. Ozzy wet subframes mounted straight up. The tower top is a completely different pressing. No spacer is used. The towers on the wet subframes are actually a little taller (about 1/2") than the dry ones. |
Author: | michaelb [ Tue Dec 07, 2010 7:47 am ] |
Quote: The Ozzy Dry Subframes have a spacer about 1/4" thick .
Oops! Does that mean I need to look for some spacers.. ![]() |
Author: | simon k [ Tue Dec 07, 2010 9:36 am ] |
michaelb wrote: Quote: The Ozzy Dry Subframes have a spacer about 1/4" thick . Oops! Does that mean I need to look for some spacers.. ![]() yep ![]() |
Author: | mtsmini [ Tue Dec 07, 2010 9:47 am ] |
Post subject: | subframe |
Hey...I remember taking them off. Now where did I put them?! ![]() |
Author: | awdmoke [ Tue Dec 07, 2010 9:51 am ] |
They'll be hiding with all the valve caps you've ever lost ![]() |
