It is currently Wed Jul 30, 2025 6:30 am
 Post subject: Triple Clock Reno
PostPosted: Tue Dec 07, 2010 4:53 pm
Hey Guys,
Im looking to spruce up the triple clocks somewhat, ie change up the face plates behind them and lighting etc.
First off has anyone changed the bulbs to led's ie something pretty coloured.
Secondly for the actual face plates, has anyone got any templates in KM/H? all the templates I can find for customs are in MPH.
Thirdly assuming I scan one a current plate and make a cool template from them, what would you recommend printing onto?
Has anyone done anything similar with good results?
So... I'm Seifer
PostPosted: Tue Dec 07, 2010 5:05 pm
Someone here did some neat faces on a printer a while back, I think it may have been Meeni.
I will try the search..
PostPosted: Tue Dec 07, 2010 5:09 pm
Yep, it was meeni...
In this thread...
http://www.ausmini.com/forums/viewtopic.php?p=521294&#521294
PostPosted: Tue Dec 07, 2010 5:31 pm
Before you make some, have a look at Mini Spares (UK) they have quite a few different face plate sets.
If you still want to print your own, I do them on clear sheets that are self adhesive, you need to do them with ink jet, however be aware that any printed ones will fade if in the sun for any an extened period.
I have LEDs that are a straight swap for the originals. A little brighter and a lot whiter than the originals.
PostPosted: Tue Dec 07, 2010 5:48 pm
NAV-MAN
It's not hard to make your own. I'm still in ideas mode atm and this is 1 of them. I was also thinking of getting them printed on vinyl.
Click on the pic for the full size. It does print at the actual size for the guages though.
All I did was scanned the face plates and went nuts in photoshop. I havent gotten around to the speed part yet. but it will be themed accordingly. The black holes and rectangle represent where the needle, faceplate screws and odometer are located.
PostPosted: Tue Dec 07, 2010 6:11 pm
I did these a few years ago, drew them in CAD and had them digitally printed onto vynil.
Don't worry about what units the templates are in, if making your own you can change them (except for the odometer). I never got to a finished design, I abandoned them all together in favour of something else, but I proved what I wanted to do.
:D
PostPosted: Tue Dec 07, 2010 7:21 pm
Give Ash some flowers Nick .
I like that font Harley. It's kinda modern looking.
PostPosted: Tue Dec 07, 2010 8:19 pm
These guys make some nice ones and they do them in KMPH as well.
Cheers Pete
http://www.heagren.com/gallileo/clocks4.php
PostPosted: Thu Jul 21, 2011 10:04 pm
Sorry to pull this thread back up but I bought a set of the gallileo gauge cover things as above however my gauges are a different style to those that are posted above and won't fit (the numbers are printed on the outer ring). What gauges am I looking for to make this work, im guessing they aren't clubman.
So... I'm Seifer
PostPosted: Thu Jul 21, 2011 10:18 pm
You want to find a set of rover gauges, from about 85-96 build year, or 85-00 if you don't need the tacho.
PostPosted: Thu Jul 21, 2011 10:26 pm
bugger, i knew it seemed to easy...
So... I'm Seifer
PostPosted: Fri Jul 22, 2011 7:29 am
They're often referred to as Nippon Seiki gauges. They changed manufacturers for these. I bought a set off UK ebay and the magnolia faces from Minispares in the UK. My only issue is that they're not in KMH. There are small numbers around the face for KMH. If anyone has any good solutions for how to change these gauges to read in km, I'd be happy to hear them.
Cheers, Matt
Don't be fooled, Gruhms is not my real name.
PostPosted: Fri Jul 22, 2011 8:05 am
If they are 110 mph you could just switch the face over to 180kmh ones from the site ousted above.
Anyone selling rover gauges?
So... I'm Seifer
PostPosted: Fri Jul 22, 2011 12:35 pm
I might be able to help you out Siefer. I have an 87 Mayfair with the triple clocks I am going to pull apart soon.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Fri Jul 22, 2011 12:40 pm
fantastic, let me know.
So... I'm Seifer
