Panthersteve wrote:
The factory fitted aerial on the 1275LS they had a little cover plate mounted under the inside mirror mount to access the aerial bolt which was just behind the mirror. So you could change the aerial without touching the headlining.
I don't know if they did that on the SS and the LS though.
Sure you could undo the bolt but how could you remove it, the cable goes through the roof space to go down the A pillar.
edit: I think I've just had an epiphany, the cable bolts on as well doesn't it
Bingo. (Or at least I think so. It was 1988 when I last had one apart.
How come I can remember the year but I can't picture what the aerial looks like.
From a dim memory the cable has a banjo like fitting and the aerial pokes through the roof and the cable banjo and then a nut and washer hold it together.
