It is currently Sat Jul 26, 2025 10:18 pm
PostPosted: Thu Dec 16, 2010 7:55 am
I am thinking about fitting disks, do I need to fit a booster? The drum brakes need plenty of pedal pressure to stop, surely the disks can't be worse.
PostPosted: Thu Dec 16, 2010 7:56 am
Nope. I prefer my brakes without a booster!
PostPosted: Thu Dec 16, 2010 8:08 am
I think the general consensus is no booster with 8.4 inch discs, but use a booster with the 7.5.
Having said that, there are plenty of people who use no booster with the 7.5, because they don't like the mushy feel. It's really up to your preference. If you're going with 7.5's, put the discs in first, and if it's too firm, stick a booster in.
PostPosted: Thu Dec 16, 2010 9:26 am
I'm not using a booster with my 7.5's.
They're fine. Though if your other half is driving the car I would recommend one. They take a bit of force.
PostPosted: Thu Dec 16, 2010 10:08 am
Depends on the pads you intend to fit. It does take some getting used to if your other daily drive is an over braked touchy Volvo or Toyota. I must admit I've had a few of these moments :shock: in the Mini but it always pulled up fine.
For the record I've got boosted 8.4" discs on the Rover and non boosted on the other Mini with 7.5" 4 pots and for spirited driving I much prefer the non boosted brakes. For a daily commuter i would lean towards boosted discs.
2008 Prado GXL
PostPosted: Thu Dec 16, 2010 10:46 am
I had one fitted, used to need a good stomp
PostPosted: Thu Dec 16, 2010 11:15 am
You get much better feel without the booster, but at the cost of having to push harder.
I would never fit a booster while I still have two good legs!
PostPosted: Thu Dec 16, 2010 11:32 am
I have 7.5s with no booster. I have fitted EBC greenstuff and it's like having a booster.
PostPosted: Thu Dec 16, 2010 4:44 pm
I have one with 8.4's and one with 7.5's both without booster. However the moke will get 8.4's with a booster (Rover master/booster). Maybe I've gone soft?
I'll let ya know what I prefer once the Moke is done.
PostPosted: Thu Dec 16, 2010 5:08 pm
Never used a booster on my 7.5"s and never felt the need for one.
Jacob
PostPosted: Thu Dec 16, 2010 8:02 pm
same as Jacob,
never found the need for it, on either my 7.5 or 8.4 discs..
Personal preference for all tho, like previously mentioned..
PostPosted: Thu Dec 16, 2010 8:15 pm
Online
I don't run one with my 7.5" discs (using greenstuffs or blackstuffs) but I'm putting a recond one in the van for the missus. :P
PostPosted: Thu Dec 16, 2010 8:24 pm
I find it much easier to modulate the brakes when driving hard (with either foot as needed) without the booster. Like said, its all about the feel and with two good legs, I don't need a booster.
michael
PostPosted: Thu Dec 16, 2010 10:45 pm
NAV-MAN
I'm glad to hear the booster is a preference thing. as I'm going from drums to 4 pot 8.4's
One thing I never hear mentioned is the master cylinder. would it be a good idea for it to be changed if going from drums to discs? And is there a benefit to increasing or decreasing the size of the bore in the master cylinder?
PostPosted: Thu Dec 16, 2010 10:49 pm
Nav my 1275LS is 8.4 with no booster and seems fine to me. Get in touch if you want to take it for a spin round the block. It is not 4 pots but should give you an idea.
My Postcode is 4500..
Alec
Users browsing this forum: drmini in aust and 90 guests
