Haynes Manual Terminology Translated into Common English
https://www.ausmini.com/forums/viewtopic.php?f=2&t=6769
Author:  Gadgets mini [ Sat Apr 30, 2005 8:05 am ]
Post subject:  Haynes Manual Terminology Translated into Common English
Found this in Minifinity very funny it explains it very well
Changes made to suit our Location (Aust.)
Haynes: Rotate anticlockwise.
Translation: Clamp with Visegrips then beat repeatedly with hammer anticlockwise.
Haynes: This is a snug fit.
Translation: Clamp with Visegrips then beat repeatedly with hammer.
Haynes: This is a tight fit.
Translation: Clamp with Visegrips then beat repeatedly with a hammer.
Haynes: As described in Chapter 7...
Translation: That'll teach you not to read through before you start. Now you are looking at scary photos of the inside of a gearbox.
Haynes: Pry...
Translation: Hammer a screwdriver into...
Haynes: Undo...
Translation: Go buy a tin of WD40 (giant economy size).
Haynes: Retain small spring...
Translation: PINGGGG - "Jesus, where the hell did that go?"
Haynes: Press and rotate to remove bulb...
Translation: OK - that's the glass bit off, now fetch some good pliers to dig out the bayonet part and tweezers to dig glass out of finger (and maybe a Bandaid or two).
Haynes: Lightly...
Translation: Start off lightly and build up till the veins on your forehead are throbbing then clamp with Visegrips then beat repeatedly with hammer.
Haynes: Weekly checks...
Translation: If it isn't broken don't fix it.
Haynes: Routine maintenance...
Translation: If it isn't broken, it's about to be. We warned.
Haynes: One spanner rating.
Translation: An infant could do this... so how did you manage to **** it up?
Haynes: Two spanner rating.
Translation: Now you may think that you can do this because two is a low, teensy weensy number... but you also thought the wiring diagram was a map of the Tokyo underground (in fact that would have been more use to you).
Haynes: Three spanner rating.
Translation: Make sure you won't need your car for a couple of days.
Haynes: Four spanner rating.
Translation: You're not seriously considering this are you?
Haynes: Five spanner rating.
Translation: OK - but don't ever carry your loved ones in it again.
Haynes: If not, you can fabricate your own special tool like this...
Translation: Hahahahahahahahahahahahahahahahahahahahahahaha :lol: :lol: :lol: :lol: .
Haynes: Compress...
Translation: Squeeze with all your might, jump up and down on it, throw it at the garage wall, then find some Visegrips and a hammer...
Haynes: Inspect...
Translation: Squint at really hard and pretend you know what you are looking at, then declare in a loud knowing voice to your wife "Yep, as I thought, it's going to need a new one"
Haynes: Carefully...
Translation: You are about to suffer deep abrasions.
Haynes: Retaining nut...
Translation: Yes, that's it, that big spherical blob of rust.
Haynes: Get an assistant...
Translation: Prepare to humiliate yourself in front of someone you know.
Haynes: Turning the engine will be easier with the spark plugs removed.
Translation: However, starting the engine afterwards will be much harder. Once that sinking pit of your stomach feeling has subsided, you can start to feel deeply ashamed as you gingerly refit the spark plugs.
Haynes: Refitting is the reverse sequence to removal.
Translation: Yeah, right. But you swear in different places.
Haynes: Prise away plastic locating pegs...
Translation: Snap off...
Haynes: Using a suitable drift...
Haynes: Everyday toolkit
Translation: NRMA, RACV, RACQ etc Card & Mobile Phone
Haynes: Apply moderate heat...
Translation: Unless you have a blast furnace, don't bother. Alternatively, clamp with Visegrips then beat repeatedly with hammer.
Haynes: Index
Translation: List of all the things in the book, bar what you need to do.
I can at least identify with a couple of them :oops: :oops:
any one else??
Author:  grub [ Sat Apr 30, 2005 8:51 am ]
:D :D :D :D :D
Had me in stitches! Gold!
Author:  FatMaserati [ Sat Apr 30, 2005 12:47 pm ]
Oh man that's hilarious.
"clamp with Visegrips then beat repeatedly with hammer" = the solution to everything.
Author:  scotty [ Sat Apr 30, 2005 2:38 pm ]
Made my day! Damn that was funny!
Author:  midlifeminicrisis [ Sat Apr 30, 2005 3:15 pm ]
hee heee...pls don't post artcles like this when I'm on my eigth Wild Turkey :lol: :lol: :lol: It really hurts to laugh so much :lol: :lol: :lol: Absolute classic... :lol: :lol: :lol: :lol:
Thanx heaps for the merriment!
Author:  sg [ Sat Apr 30, 2005 3:25 pm ]
Thats some funny s&^t right there :lol:
Author:  min13k [ Sat Apr 30, 2005 9:56 pm ]
and of course if the vice grips and hammer dont work get a bigger hammer and if that dont work get a oxy set :D
that is a good read
pisser
makka
Author:  Mini Mad [ Sat Apr 30, 2005 10:12 pm ]
haha damn that hurt my stomach.. :lol:
Author:  supercharged 850 [ Sun May 01, 2005 1:50 am ]
Yeah... I can agree with that too.
I think they missed one though.
HAYNES: UNDO THE 1/2 INCH NUT
Translation:
1. Round off the top half of the 1/2 inch nut.
2. Use a drill or hack saw to remove the remainder of the nut and the end of the stud.
3. Use vice grips and a hammer to remove the remainder of the stud
4. Replace with a different stud, bolt and washer.
OR
1. Undo the nut with a socket wrench and breaker bar, which will then extract the stud at the same time, without unlocking the nut from the stud.
2. Replace with a different stud, bolt and washer.
Author:  Rodney [ Sun May 01, 2005 1:34 pm ]
Instructions on how to butcher your mini LOL Bloody good laugh heh :D
Author:  68matic [ Sun May 01, 2005 2:23 pm ]
Those bastards at Haynes
i can just imagine them poms laughing their heads off while writing this
Author:  BeanMe [ Mon May 02, 2005 12:58 am ]
Post subject:  g
CLASSIC!
Author:  Gadgets mini [ Mon Jan 22, 2007 1:47 am ]
this deserves another run for the newer members :wink:
Author:  adeee [ Mon Jan 22, 2007 6:01 am ]
thankyou gadget. thats funny stuff. Were you bored at work last night or something?
Author:  Lillee [ Mon Jan 22, 2007 7:49 am ]
PMSL! hahaha Classic!
