It is currently Wed Jul 09, 2025 10:59 pm
PostPosted: Tue Dec 14, 2010 7:46 pm
so I got my mega jolt working woo.. finally!
but!!! i was super clumsy & used a screw driver wedging it off.
i was not thinking until that split moment after i did and thought, hmmm that was not a good idea nick...
yes i damaged the oil seal & i bent the case a bit & i can hear the timing chain touching the timing cover and it's dripping oil a bit now :( :oops:
so what is the best way to take this sucker off.
maybe a puller of some sort? bit hard to get a hammer in there.
once i take it i can just tap it back with a hammer?
torque is 70ft on that balancer yes?
im going to attack this tomorrow morning and fix it up so i can start to play with my mega jolt :D
PostPosted: Tue Dec 14, 2010 7:53 pm
i got a puller and a cover u can use
0418666609
PostPosted: Tue Dec 14, 2010 8:13 pm
thanks dodge.
i do have a puller can i use my old timing cover? i mean i would have only bent it a touch?
thanks heaps for the offer :D i have never done it before but it looks very easy.
PostPosted: Tue Dec 14, 2010 8:16 pm
If you need to change the cover just make sure that you get the right type. The A+ has a different shape to the normal common ones.
PostPosted: Tue Dec 14, 2010 8:17 pm
im using a cooper s one on a A+ motor as i need it to clear the sc12.
not had a problem.
PostPosted: Tue Dec 14, 2010 8:20 pm
Ok, next point to look at. The early covers have the seal pushed in from the front and the later covers have the seal pushed in from the rear. :D
PostPosted: Tue Dec 14, 2010 8:29 pm
ok thanks morris.
i will look over carefully how it comes out. does it just push in?
are any hammers involved in this :lol:
PostPosted: Tue Dec 14, 2010 8:30 pm
You should be able to knock your cover back into shape as long as you haven't really molested it.
Making sure that you don't distort the gasket face of the cover
PostPosted: Wed Dec 15, 2010 4:17 pm
nick nick nick, wat r we going to do with u... :roll: 8)
PostPosted: Wed Dec 15, 2010 9:05 pm
so lol i seem to of broke the timing chain as well :lol:
only snapped a bit of the link cover but not point trying to fix it.
ill just put a new one in. oh well what a blunder :roll:
PostPosted: Sat Dec 18, 2010 12:00 pm
Seeing as you have to replace the timing chain, replace it with a double row chain.
Rod Image
PostPosted: Sun Dec 19, 2010 10:18 am
thanks rodney. i had a double originally :) used the german roller master one?
PostPosted: Sun Dec 19, 2010 12:59 pm
Mmmm....German bits........
Rod Image
