Removing fuel tube - with or without subframe?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=67728
Author:  mtsmini [ Sun Dec 19, 2010 2:47 pm ]
Post subject:  Removing fuel tube - with or without subframe?
The solid tube that goes from the rear to the front. Do I have to remove the rear subframe to remove and fit it or can it be taken out and in with the subframe in place?
Author:  GT mowog [ Sun Dec 19, 2010 3:57 pm ]
You won't be able to do it with the rear subframe in place, but you may not have to take it right out either. If you leave the rear mounts bolts up and maybe the the shocks, you might be able to swing it down just far enough to get the fuel tube (and brake line, battery cable and what ever else) out and / or in.
I've have only ever done it while the subframe has been completely out for other reasons though.
Author:  mtsmini [ Sun Dec 19, 2010 9:10 pm ]
Post subject:  fuel line
Bugger - and I've just fitted the rear subframe!
Anything else I have to fit with the subframe out? Brake line?
Author:  GT mowog [ Mon Dec 20, 2010 5:30 am ]
Post subject:  Re: fuel line
Thought you'd say that!
Fuel Line (LHS)
Battery Cable (RHS),
Brake Line RHS),
Vapor Return Line (RHS - if it has one)
Author:  mtsmini [ Mon Dec 20, 2010 9:17 am ]
I have a cunning plan...I'll try tonight...
Author:  Moriarty [ Mon Dec 20, 2010 9:44 am ]
Fuel Line (LHS)
Brake Line RHS),
Handy information that - cheers! :)
