It is currently Tue Jul 22, 2025 6:58 pm
PostPosted: Tue May 17, 2005 9:21 am
hey all, On the cast-iron inlet manifold (standard).. what is the thread on either end ?
Sometimes it has a brass plug, but there is usually one open thread with a barbed fitting or somthing.....
I'm wanting to put a Hobbs switch in there and need a 1/8BSP Female thread to put it into .....
Little help ?
J
PostPosted: Tue May 17, 2005 1:08 pm
vacuum supply for boosted brakes?
-Cam 8)
IS NOW BACK ONLINE AFTER SOMETIME..... SORRY TO ALL, FOR NOT REPLYING TO PM'S!!
PostPosted: Tue May 17, 2005 1:34 pm
Yes, possibly.. but what is the actual thread ?
I'm hoping its 1/8 BSP .....
J
PostPosted: Tue May 17, 2005 1:57 pm
ahhh sorry man, cant help ya...
kevs the man :wink:
-Cam 8)
PostPosted: Tue May 17, 2005 10:12 pm
kazjim are u using a standard inlet manifold for your turbo setup. if s did u have to remove a fairly large amount of material for the 1 3/4" carb
PostPosted: Wed May 18, 2005 10:02 am
Nope, Made a 3/4" thick spacer out of Plate steel and bored it 1 3/4" ......
no hassles there....
J
PostPosted: Wed May 18, 2005 10:17 am
it is a unf thread....... thats all i know, put a bolt with 7/16 head in there ( dont know thread size)
lookin for another clubby
