It is currently Sat Jul 19, 2025 1:42 am
 Post subject: Xmas hols road trip
PostPosted: Tue Dec 21, 2010 11:55 am
Hi folks.
On Boxing Day we'll be heading from Sydney to Urunga Heads with a fly loaded mini towing my new trailer to go camping for a few days.
Just wanted to ask a couple of things. First any advice on what to do to prepare the car for being so heavily loaded for the trip. Secondly which spares should I pack?
Also is there anyone that lives between Sydney and Urunga Heads that's willing to be an emergency contact in case of breakdown (or to give me names of mechanics etc)?
PostPosted: Tue Dec 21, 2010 12:08 pm
NRMA roadside assistance?
PostPosted: Tue Dec 21, 2010 12:12 pm
Hopefully things have changed but I doubt it....
be prepared for very heavy traffic leaving Sydney on Boxing day...
I once got stuck in a traffic jam for many hours - constant stop start stuff....
Was very glad I had air con that day... (wasn't in a mini)
So make sure you have plenty of food and drink....
And check your cooling system is all OK before you go.
I used to head up to Byron Bay from Canberra in my mini - and no dramas at all if the car is basically OK.
Suonds like a good trip - have fun.
PostPosted: Tue Dec 21, 2010 4:10 pm
Got NRMA cover already.
Checking water, oil, tyres, petrol, wipers, lights, brake fluid before we go.
It's got new spark plugs from a couple of weeks back. Will take oil, water, coolant, spark plugs, leads, jump cables, cable ties, jack, basic tools.
PostPosted: Tue Dec 21, 2010 4:38 pm
Rover Cooper
IT wont be a genuine trip in a mini unless there are problems thats what we all try to achieve by loving these tempermental little gems, remember its the smiles from other drivers that make them a joy to drive.
goog luck and many happy smiles, and merry X<MAS to all...... :lol: :lol:
PostPosted: Tue Dec 21, 2010 5:12 pm
I'd also pack some points and spare fuel.
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Tue Dec 21, 2010 8:04 pm
Fan belt?
Cooper S Mk2
Cooper S Mk1
PostPosted: Tue Dec 21, 2010 8:44 pm
cool, have fun!
i'd look at taking..
fuses, wire, side cutters, pliers, shifter (adjustable wrench), big ass torch, fan belts, WD-40.
since your fully loaded and towing id make sure the brakes are in top working order, maybe put a new set of pads in the front as it can be quite hilly and on a long trip you don't want to have to worry about them.
PostPosted: Tue Dec 21, 2010 8:54 pm
:lol:
I don't think we used to take that many spares when we did the moke trips thru the out back :)
How often is your mini serviced? How old is the motor (as in when was it last rebuilt.... if ever?).... does it tend to give you trouble? How often do you take it out, and what kind of driving do you do in it?
If its serviced at normal intervals, and you check everything over each time, and its not a naughty mini most of the time, you should be fine :) just take a 7/16" spanner, a 1/2", a 9/16, a Phillips screwdriver, a flat blade screw driver and a pair pliers.... and """IF"""" anything goes wrong you'll have the tools you need.... but if its serviced normally you shouldn't need to take a second support vehicle just to carry parts :lol: besides, you're on main roads for most of that trip, so you'll never be far from help :)
Hope you have a blast and I'll probably see you on the road :)
<edit> check your wheel bearings before you leave :shock: thats not fun! and yeah, to be fare I always carry spare fuses in all my cars, and tools and a torch... Just give your car a good inspection before you leave....
Tyre pressure
Wheel bearings
brakes (fuild and pads/shoes)
look at your CV's
change the oil + filter
check coolant
check air filter
and you should be sweet :)
PostPosted: Tue Dec 21, 2010 8:56 pm
Yep, was thinking about fan belt today as i posted this earlier. Will give Karcraft a call in the morning and see if they can express me one for thursday/Friday.
Don't need points as electronic dizzy
Fuel, yes, will dig out fuel can and add it in
Fuses, tools, torch (going camping so we've got a ton of torches anyway), WD40, check.
New EBC Green stuffs went on in Aug/Sep and the master cylinder and brake proportioning valve were replaced as well.
Ta
On the subject of getting out of Sydney on the 26th. Do you think if we hit the F3 by 7.30am we'd be OK. Very keen to avoid getting stuck in traffic.
PostPosted: Tue Dec 21, 2010 9:02 pm
Mobile Phone
PostPosted: Tue Dec 21, 2010 9:18 pm
[On the subject of getting out of Sydney on the 26th. Do you think if we hit the F3 by 7.30am we'd be OK. Very keen to avoid getting stuck in traffic.[/quote]
No, you will probably be right in thge thick of it.
But having said that...with all the new road opened up north of Hexham you might be ok
