It is currently Mon Jul 28, 2025 3:57 pm
 Post subject: Air Injection Unit
PostPosted: Tue Dec 28, 2010 6:08 pm
In regards to removal of the set-up, does the inlet manifold need to be blocked up where the air hoses connect in the two places?
Does removing the pump and set-up affect anything else?
I'm just tinkering and thinking about the whole thing at the moment.
1977 LEYLAND MINI SUNSHINE 'S'
 Post subject: Re: Air Injection Unit
PostPosted: Tue Dec 28, 2010 7:24 pm
Yes it does need to be blocked. The small connection can just be squeezed shut, plug the big one.
The only thing air pump removal will do is liberate another pony or two to do meaningful work.
PostPosted: Tue Dec 28, 2010 7:28 pm
And probably increase the power to weight ratio significantly after jettisoning the weight of a boat anchor :lol:
PostPosted: Tue Dec 28, 2010 7:36 pm
Ok.
So what do I do with the Gulp Valve?
Does it matter if its taken off?
PostPosted: Tue Dec 28, 2010 7:44 pm
Take it off and plug the hole.
All the plumbing on the front of head can be removed, the threads in the head are 7/16 UNF. I used grub screws. Another easy and cheap method is screw old seat belt bolts in, and then cut them off flush with an angle grinder.
PostPosted: Tue Dec 28, 2010 7:58 pm
OK now Im clear on it all now.
Thankyou very much.
I took the pump, belt, hoses and the injection pipes on the head off. Just wasn't sure about the Gulp Valve. Now I am :wink:
With the injection system designed in conjunction with leaded petrol, when I took the injection pipes off ALL four of them were fully blocked with dirt and hard crud and in no way what so ever could be possibly be injecting air anyway, even though it was already doing nothing if it was unblocked..............
PostPosted: Tue Dec 28, 2010 8:11 pm
There is no legal requirement to keep the ADR27a pollution gear anymore.
ADR27a was repealed and in theory no longer exists. You can't comply to something that doesn't exist. :lol:
PostPosted: Tue Dec 28, 2010 8:16 pm
Yeah exactly, it was doing nothing anyway.
PostPosted: Tue Dec 28, 2010 8:19 pm
Yeah I love how the system was supposed to "burn un-burnt hydrocarbons" in the exhaust, but it always looked like just dilution of the exhaust to me!
The environmental scientists I've worked with in the past have always reckoned "dilution is not the solution" so no wonder it was repealed. :lol:
Jacob
PostPosted: Tue Dec 28, 2010 8:20 pm
Don't chuck it out though
It may be of use to someone doing an original restoration
