Is this normal?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=67887
Author:  Tito [ Tue Dec 28, 2010 1:53 pm ]
Post subject:  Is this normal?
Have only had my Mini a couple of weeks, and was just wondering if this is the norm? It has a 1275 motor, and a webber single carb. Every time I start it, I get quite allot of black smoke, and it runs like poop. It sounds like it's running on three cylinders. It does this all the way up to running temp, (about 5 minutes) then runs like an absolute dream, and no smoke.
Do others cars do the same?
Thanks in advance. :D
Author:  mickmini [ Tue Dec 28, 2010 2:09 pm ]
are you using the choke to start it cold?
If it is running on 3 cylinders at start up, it sounds like the plugs are getting fouled. It probably needs a proper tune (jetting and timing), but try cleaning the plugs using the drmini blowtorch method and try again.
black smoke usually indicated too rich a mixture, which is easy to do if you are using the choke and the mixture is already at the rich end of the scale.
michael
Author:  drmini in aust [ Tue Dec 28, 2010 2:29 pm ]
Most people with sidedraft Webers (me included with 45 Dellorto) don't bother with the choke- just pump the throttle a few times then turn the key.
If I use the choke and leave it on for long, I can foul a plug too. :lol:
Author:  Tito [ Tue Dec 28, 2010 5:21 pm ]
I have been using the choke, on full too, as that was what I was told to do by the previous owner. Will try it tomorrow with no choke.
Thanks heaps guys. :D
Author:  mickmini [ Wed Dec 29, 2010 8:42 am ]
I only used the choke when it was less than 5*C over in NL and only until the temp got to about 40*C on the guage.
michael
