It is currently Wed Jul 23, 2025 3:50 pm
PostPosted: Thu Apr 07, 2011 7:50 pm
Hi Everyone, I have just finished timing my new cam in, couldn`t have done it without everyones help on this forum, so thanks. I now want to set rocker clearances, but in my Gregories book is says valve rocker clearances for timing, 0.019".Just a bit lower down it also says valve rocker clearances cold 0.012" Can anyone tell me which one it is ?? :? :? :?
Jethro
PostPosted: Thu Apr 07, 2011 7:53 pm
What cam is it?
.012" was running clearance for stock cams, most sporty aftermarket ones run bigger clearance.
eg Kent cams = .016"
Russell Engineering's RE13 and RE83 = .016"
These figures are for stock or 1.3:1 rockers, add .003" for 1.5:1 rockers.
PostPosted: Thu Apr 07, 2011 8:07 pm
Hi Doc, it`s an RE 13 from GR.
So how come the book gives a valve clearance for timing of 0.019"
Jethro
PostPosted: Thu Apr 07, 2011 8:39 pm
The factory manual gives a bigger clearance (.019", or sometimes .021")for CHECKING the VALVE TIMING, that is all it is used for.
And, that is only for use with the original BMC cams, not Kents, REs etc, many of which use .016" for checking.
There is NO standard clearance for checking cam timing that's used by everybody.
BTW,
High performance cams often use even bigger running clearances, my RE282 uses .022"/.024" with 1.5:1 rockers.
PostPosted: Thu Apr 07, 2011 10:37 pm
OK thanks doc.
Jethro
