It is currently Sun Jul 20, 2025 6:42 pm
PostPosted: Fri Dec 31, 2010 11:23 am
hi,need to know how to remove the door mirrors from a clubman,they are the original leyland mirrors.
thanks in advance
jayson
PostPosted: Fri Dec 31, 2010 12:10 pm
If they are the ones I am presuming them to be there is a grub screw to lock the mirror onto a mounting plate that is screwed to the door. The grub screw is in the "base" part of the mirror that screws into the end facing towards the front of the car, it is very close to where the arm goes into the base.
Hope this makes sense and helps.
Steve
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Fri Dec 31, 2010 12:26 pm
thanks steve,i think i know what you mean.
jayson
PostPosted: Fri Dec 31, 2010 12:51 pm
I have some photos that show it clearer if it helps...
PostPosted: Fri Dec 31, 2010 12:59 pm
thanks for the pics,greatly appreciated.yep i got it under control now.
jayson
PostPosted: Fri Dec 31, 2010 1:01 pm
I forgot to say that you may need to rotate the arm to get the recess for the screw to line up.
PostPosted: Sat Jan 01, 2011 1:12 pm
many thanks morris1100,mission accomplished
jayson
