1 1/2 SU needle https://www.ausmini.com/forums/viewtopic.php?f=2&t=67960 |
Author: | REALXSBASS [ Fri Dec 31, 2010 10:23 am ] |
Post subject: | 1 1/2 SU needle |
Hi all, Just wondering roughly what the correct needle would be for a 1275 which has been bored to 1310 with ground cam? Just for running in, your help is much appriciated Cheers James |
Author: | TheMiniMan [ Fri Dec 31, 2010 10:42 am ] |
depends on a whole heap of variables like cyl head mods, cam choice, inlet design/shape & exhaust system but still you can try DZ BQ #6 etc etc etc |
Author: | REALXSBASS [ Fri Dec 31, 2010 12:12 pm ] |
does ABB / AB8?? sound familiar to n e one? |
Author: | TheMiniMan [ Fri Dec 31, 2010 1:07 pm ] |
ok, yeah that`s the later "Bias" (Swinging) needle type , commonly called "Self-centering" the needles i`ve listed would only be "starter" needles & depending on how the car reacts to one of those needles you`d then be able to make a discission as to where to go from there but the later swinging needle type carb you sound like you have, to use the neddles that i`ve suggested , you`d have to buy the "Fixed-needle-adapter" to fit them |
Author: | REALXSBASS [ Fri Dec 31, 2010 2:16 pm ] |
yeh its the swinging type. Would the abb needle be ok for running? |
