How to Remove Clubman Door Mirrors https://www.ausmini.com/forums/viewtopic.php?f=2&t=67962 |
Author: | 76van [ Fri Dec 31, 2010 11:23 am ] |
Post subject: | How to Remove Clubman Door Mirrors |
hi,need to know how to remove the door mirrors from a clubman,they are the original leyland mirrors. thanks in advance jayson |
Author: | Panthersteve [ Fri Dec 31, 2010 12:10 pm ] |
If they are the ones I am presuming them to be there is a grub screw to lock the mirror onto a mounting plate that is screwed to the door. The grub screw is in the "base" part of the mirror that screws into the end facing towards the front of the car, it is very close to where the arm goes into the base. Hope this makes sense and helps. Cheers Steve |
Author: | 76van [ Fri Dec 31, 2010 12:26 pm ] |
thanks steve,i think i know what you mean. cheers jayson |
Author: | Morris 1100 [ Fri Dec 31, 2010 12:51 pm ] |
I have some photos that show it clearer if it helps... ![]() ![]() ![]() |
Author: | 76van [ Fri Dec 31, 2010 12:59 pm ] |
thanks for the pics,greatly appreciated.yep i got it under control now. cheers jayson |
Author: | Morris 1100 [ Fri Dec 31, 2010 1:01 pm ] |
I forgot to say that you may need to rotate the arm to get the recess for the screw to line up. |
Author: | 76van [ Sat Jan 01, 2011 1:12 pm ] |
many thanks morris1100,mission accomplished cheers jayson |
