Morris 1100
https://www.ausmini.com/forums/viewtopic.php?f=2&t=67977
Author:  dalej [ Sat Jan 01, 2011 9:34 pm ]
Post subject:  Morris 1100
Would I be correct in assuming the Morris 1100 has the same engine in it as a mini 1100?? If so would it be a easy transplant.? Thanks
Author:  drmini in aust [ Sat Jan 01, 2011 9:38 pm ]
Basic engine is same, gearbox is not quite.
1100 is 3 synchro not 4, and has a 4.26:1 diff ratio. useless in a road Mini.
Remote shift housing setup a bit different too.
Engine mount setup is different at crank pulley end.
Pull the motor off the 1100 box and stick it on a Mini one.
:wink:
