fitting new cwp
https://www.ausmini.com/forums/viewtopic.php?f=2&t=68001
Author:  justfanginaround [ Mon Jan 03, 2011 10:21 am ]
Post subject:  fitting new cwp
I have been advised that if I wish to put a 3.1 cwp into my gearbox i will need to grind some bearing carrier ?
Any advise or susgestions ?
Has anyone done this before ?
cheers Jon
Author:  drmini in aust [ Mon Jan 03, 2011 10:37 am ]
The bigger pinion can foul inside the 3rd motion shaft bearing carrier. If it's a rodchange box it should/might be OK, but all remote change boxes need the carrier's inside diameter increased to 57mm approx.
It's a 5 min job in a lathe. :wink:
If no lathe you can grind it out by hand, it's only clearance.
Author:  justfanginaround [ Mon Jan 03, 2011 11:07 am ]
cool thank you the great wise doc.
is it g/box off engine job or can i do it carefully through the diff opening ?
Author:  GT mowog [ Mon Jan 03, 2011 11:12 am ]
If it's needed, you can get it off through the end cover.
