How do you calculate a modified engine's capacity https://www.ausmini.com/forums/viewtopic.php?f=2&t=6835 |
Author: | 71_mini_k [ Mon May 02, 2005 4:43 pm ] |
Post subject: | How do you calculate a modified engine's capacity |
Silly question time ![]() Looking at people's signature blocks I have noticed that engine capacity varies from the standard engine a car orignally fitted with a 1098 has become a 1132, 1144 or 1152. And a 1275 becomes a 1310 or 1380 once modified Hows is this determined? |
Author: | fuzzy-hair-man [ Mon May 02, 2005 4:53 pm ] |
1/2 the Diameter of the pistons including overbores if any square this number then multiply it by 3.14 (pi) (area of the circle that is the bore of piston) now times this by the the stroke of the engine and then times this by four cause you have four pistons This is as far as I know how it goes. Correct me if I am wrong as far as I know it doesn't take into account combustion chamber size |
Author: | 71_mini_k [ Mon May 02, 2005 5:07 pm ] |
Thanks Fuzzy but I think I'm more confussed now that before ![]() Is there a easier way like 1275 +.020" (1293), +.040" (1310), +.060" (1330), or +.115" (1380) |
Author: | fuzzy-hair-man [ Mon May 02, 2005 5:12 pm ] |
Yes I guess so but I don't know them so I can't say ![]() ![]() ![]() |
Author: | 1310/71 [ Mon May 02, 2005 5:17 pm ] |
71_mini_k wrote: Thanks Fuzzy but I think I'm more confussed now that before
![]() Is there a easier way like 1275 +.020" (1293), +.040" (1310), +.060" (1330), or +.115" (1380) Wrong Kevin, but you're spot on with the 1275cc overbore capacities there. Answered your own question in fact. KB |
Author: | FatMaserati [ Mon May 02, 2005 5:23 pm ] |
1275 can become 1430 too... ![]() |
Author: | danidad [ Mon May 02, 2005 5:25 pm ] |
as this is being discussed here might as well ask here... whats an 1100 +40 thou |
Author: | 1310/71 [ Mon May 02, 2005 5:37 pm ] |
FatMaserati wrote: 1275 can become 1430 too...
![]() yes but we were talking about overbores, not stroking as well. ![]() For that you'll have to use the formula the fuzzy haired one gave us. ![]() |
Author: | fuzzy-hair-man [ Mon May 02, 2005 6:06 pm ] |
OK using that formula and the bore size Kev gave in the other thread ( 65.6mm )and a 1100 stroke being 83.82mm Ok so convert to cm 6.56 cm bore and 8.382 cm stroke (6.56 / 2 ) ^ 2 * 3.14 = 33.79 square cm (X^2 means squared) 33.79 * 83.82 = 283.22778 283.22778 * 4 = 1132.9 1133 approximately now lets see if Kev tells me if my calculation is right in practice ![]() ![]() |
Author: | TheMiniMan [ Mon May 02, 2005 6:53 pm ] |
to work out any piston engine`s capacity---> pie x r squared--- is the formula to work out the area of a circle (pie being 3.1412,,, & r being the radius of the cyl) then times that by the length of the stroke of the crankshaft Then times that by however many cyls there are easy-peasy ![]() |
Author: | fuzzy-hair-man [ Mon May 02, 2005 6:56 pm ] |
That's what I said ![]() ![]() ![]() |
Author: | danidad [ Mon May 02, 2005 9:23 pm ] |
thats a big thanks from me peoples |
Author: | drmini in aust [ Mon May 02, 2005 10:16 pm ] |
Yes an 1100 bored to +.040" is an 1132. +.060" gives 1152. Next stop is 68.0mm (Imp pistons) for 1220cc approx. For what a decent set of UK Imp pistons is worth now, you could buy a 1275... ![]() |
Author: | danidad [ Mon May 02, 2005 10:40 pm ] |
thanks again doc the previous owner said the motor had been rebuilt twice the most recent not that long ago mileage wise... motor looks good and everything else he said has checked out so far... (he was a good bloke) so i wont be touching the bore, only pulled it open to make sure things looked right. centre oil pickup is the only job im intending to do to the innards at this stage. |
Author: | 71_mini_k [ Tue May 03, 2005 9:23 am ] |
Thanks for everyone's input. ![]() I just had my engine and gearbox rebuilt and during the process I was informed that my 1098 has been bored to +.040 and I wanted to know how to recalculate the capacity. I am now looking forward to the next dyno day so I can see how much power I have gained as I had the diff changed, a road/rally cam fitted and I was already running twin SU and extractors. ![]() |
