It is currently Fri Aug 08, 2025 7:53 am
PostPosted: Thu Jan 27, 2011 3:56 pm
Gday all.
About to takel making a pattern of the mini bulkhead soundproffing piece i did one ages ago but have since lost the pattern i made.
I wanted to ask here befour i did it again just in case anyone had a guide on making one...messurments etc
or should i just buy one...
its for a 66 deluxe. but needs to be modified as im not using the heater hole etc.
if no one has one il make up a pattern again and wack it in the how to do section for all to use.
PostPosted: Thu Jan 27, 2011 6:05 pm
I have a paper template made from an original Cooper S.
You're welcome to come and make a copy of it if that helps.
PostPosted: Fri Jan 28, 2011 8:47 pm
If you could still make up the pattern and post it would be brilliant :wink:
