kaka wrote:
Has anyone every welded the flywheel to the crank to stop the flywheel coming off. The rest of the motor is fresh, the crank is at its final grind,and would be discarded when and if the motor was to be rebuilt again. Just sick of the flywheel coming loose on the crank and don't really want to pay for a new crank unless I have too.
Three questions... and a suggestion
1. What is the condition of the tail of the crank?
2. What is the condition of the taper inside the flywheel?
3. What are you torquing it up to?
If you're torquing it up correctly and its still coming loose... there is a few possiblities.
The flywheel bolt is there to lock the flywheel on the taper... If the tapper is worn or the tail is worn to a point where the bolt is tigthening agains the end of the crank and not the flywheel, you will not be able to get enough loading on the flywheel to lock it on the taper.
Likewise, it the tail is gouged and looks like a dogs breakfast, it will not have sufficient surface area making contact with the inside taper in the flywheel....
The taper is what holds the flywheel on, not the bolt.
I would suggest, if you tail looks like crap, that you remove any high spots with a diamond lap. Then using a light smear of course valve lapping paste, lap the flywheel onto the tail. Just keep working it till it goes quiter. Then clean all the paste off. You'll be able to see clearly just how much contact there is between the tail and the flywheel (there'll be a witness mark from the paste) If is only touching it a few places, then its probably not going to get any better. If you getting 80% + contact, you my be able to lap it some more and get a better fit.
You can weld the flywheel on if you want... I think you'll find out pretty quick why you shouldn't though
<edit> sorry Doc, you bet me to it
