Rear subframe bolts https://www.ausmini.com/forums/viewtopic.php?f=2&t=68542 |
Author: | poeee [ Fri Jan 28, 2011 5:39 pm ] |
Post subject: | Rear subframe bolts |
What size and lenth bolts do I need to go through the alloy subframe mounts in to the body? |
Author: | wild_willy [ Fri Jan 28, 2011 6:06 pm ] |
5/16 UNF 4 x 2 1/2 HT bolts zinc plate 2 x 1 1/4 HT bolts zinc plate 2 x 1 1/4 HT set screws zinc plate (used for the front subframe mounts) 8 x 5/16 nylocks Can list the washers if you need. |
Author: | poeee [ Fri Jan 28, 2011 6:28 pm ] |
Oooo yes please. Do you have some kind of list? |
Author: | wild_willy [ Fri Jan 28, 2011 7:39 pm ] |
Yes I have a list. Mainly for 997 Coopers with sliding windows but much of the fasteners are common to many other model Minis. PM me your email and I'll forward my Word list of fasteners. Not 100% complete and may contain a few errors. I'll also let you know where I buy from as they have nearly all the right ones. |
Author: | poeee [ Fri Jan 28, 2011 7:41 pm ] |
Thank you muchly. PM sent. ![]() |
Author: | wild_willy [ Fri Jan 28, 2011 7:54 pm ] |
Emailed list! |
Author: | Mokesta [ Fri Jan 28, 2011 8:29 pm ] |
oooh that sound like GOLD. Can I have it too? PM on it's way. M |
Author: | wild_willy [ Fri Jan 28, 2011 9:41 pm ] |
Email to u Mokesta |
Author: | Wombat [ Fri Jan 28, 2011 9:47 pm ] |
Yes please - pretty please |
Author: | gafmo [ Fri Jan 28, 2011 9:50 pm ] |
Come on willy..just put the info up ![]() |
Author: | wild_willy [ Fri Jan 28, 2011 9:59 pm ] |
Just remember its my working doc and may contain errors. It also may refer to slightly different fasteners to OEM fasteners as not all of the original type are available now days. It was OK for me to build up a stock of parts to successfully restore 2 997 Coopers & 1 Mini K. I do intend to refine this list to include trim clips and other fiddly Mini bits. Found this mob to be pretty good and they have most fasteners needed. https://www.bolt.com.au/index.php |
Author: | brett [ Fri Jan 28, 2011 10:17 pm ] |
can you please email me a list to [email protected] THanks Brett |
Author: | Wombat [ Sat Jan 29, 2011 7:38 am ] |
Thanks WW |
Author: | brett [ Sat Jan 29, 2011 8:42 am ] |
Wow thank you so much |
