It is currently Sat Jul 19, 2025 9:24 pm
PostPosted: Mon Mar 07, 2011 6:33 pm
How are you all going ? I have a problem with a Mk 2 S. Well, maybe not a problem but just an annoyance. When I top the radiator up with water and go for a short drive and stop, water comes out of the overflow pipe. It will do this until the radiator goes down maybe 1 to 1 and half inches from the top and then it is fine and the level stays there. The car was running an 82 degree thermo but changed to a 74. The radiator cap is the standard 13 lb and is new. Any ideas please ? Thanks
PostPosted: Mon Mar 07, 2011 6:41 pm
This is normal. Water expands when heated and has to go somewhere...> =out the pipe.
Later radiators (eg Clubby) have a level indicator mark inside. Surprise surprise, it's about 1/2 way down the tank.. :wink:
If you `could' (don't try this!) see inside the tank when it's hot, you would find it is full. The air gets sucked back in as it cools, this is normal too.
PostPosted: Mon Mar 07, 2011 6:47 pm
Everything is normal. The water level is supposed to be about an inch low, the handbook for the Mk1 shows a water level indicator in the radiator and I think the Mk2 would have been the same.
PostPosted: Tue Mar 08, 2011 7:52 am
OK no worries thanks for that
