It is currently Sat Aug 09, 2025 9:08 pm
PostPosted: Sat Jan 29, 2011 6:08 pm
Does anyone know which terminal is positive/negative on the connector on top of the fuel pump assembly? One is coloured brass, the other silver if that helps.
I want to put a inertia switch in, you know, used to isolate the fuel pump in the event of a very sharp deceleration - eg a collision. Where can I get a S/H one?
Edit: This is a new one - http://www.minispares.com/Product.aspx?ty=pb&pid=42336&title=
PostPosted: Sat Jan 29, 2011 7:20 pm
Are you using a SPI/MPI fuel tank and pump?
If you are have a look at the following links
http://mini.nicehelp.co.uk/Circuit%20Diagrams.pdf (1.06 MB)
http://mini.nicehelp.co.uk/Work%20Shop%20Maunal.pdf (4.53MB)
Cheers Pete
PostPosted: Sat Jan 29, 2011 7:26 pm
Cheers Pete
Yes using EFI fuel tank. I found the "Maunal.PDF", but not the circuit diagrams. Downloading now! Thanks. :D
Jim
