Rover Fuel Pump Connection and Inertia switch
https://www.ausmini.com/forums/viewtopic.php?f=2&t=68564
Author:  jb007 [ Sat Jan 29, 2011 6:08 pm ]
Post subject:  Rover Fuel Pump Connection and Inertia switch
Does anyone know which terminal is positive/negative on the connector on top of the fuel pump assembly? One is coloured brass, the other silver if that helps.
I want to put a inertia switch in, you know, used to isolate the fuel pump in the event of a very sharp deceleration - eg a collision. Where can I get a S/H one?
Edit: This is a new one - http://www.minispares.com/Product.aspx?ty=pb&pid=42336&title=
Author:  EST-071 [ Sat Jan 29, 2011 7:20 pm ]
Are you using a SPI/MPI fuel tank and pump?
If you are have a look at the following links
http://mini.nicehelp.co.uk/Circuit%20Diagrams.pdf (1.06 MB)
http://mini.nicehelp.co.uk/Work%20Shop%20Maunal.pdf (4.53MB)
Cheers Pete
Author:  jb007 [ Sat Jan 29, 2011 7:26 pm ]
Cheers Pete
Yes using EFI fuel tank. I found the "Maunal.PDF", but not the circuit diagrams. Downloading now! Thanks. :D
Jim
