It is currently Wed Aug 20, 2025 5:23 am
 Post subject: Cooper S Head
PostPosted: Tue Feb 01, 2011 6:44 pm
hi, i need the sequence for undoing the bolts on a cooper s head.if anyone can help it would be greatly appreciated.
also can it be used on an 1100 & would there be any benefit ?
many thanks
jayson
PostPosted: Tue Feb 01, 2011 6:52 pm
Start at the ends (alternately) and work inwards. Undo the S end stud and bolt first.
[edit] Method is applicable to all A series heads.
Last edited by drmini in aust on Wed Feb 02, 2011 6:50 pm, edited 1 time in total.
PostPosted: Wed Feb 02, 2011 5:35 am
thanks very much dr mini,greatly appreciated.
jayson
PostPosted: Wed Feb 02, 2011 6:13 am
Mods rock!
If you fit it to an 1100 engine, might need to watch yr Compression Ratio, it will be higher with the C/S Head and so may lead to pinging. You may also need to make sure the valves don't kiss the block, depends on cam and rockers you have. As far as benifits go, you may loose some low RPM torque but you'll likely gain at at higher RPMs.
PostPosted: Wed Feb 02, 2011 10:23 am
thanks gt,as far as i know it`s a stock 1100 so i`ll just leave it as it is.
cheersjayson
PostPosted: Wed Feb 02, 2011 6:10 pm
My bad, I thought he was talking about the undo sequence, not whether an S head would work on a smallbore.
:oops: Now edited above post..
PostPosted: Wed Feb 02, 2011 6:16 pm
I think there were two questions and both were answered. :D
PostPosted: Wed Feb 02, 2011 6:49 pm
Mods rock!
Yeah and thanks to the Doc for the advice on extraction :P
Users browsing this forum: No registered users and 70 guests
