Hi mini machine, welcome to ausmini!
Your misfire at idle sounds like it may be the fueling. If it's running lean or rich, you can expect a misfire. If the misfire is rhythmic, it's likely to be too rich, if it's random it's likely to be lean.
If you check the spark plugs, you can usually tell how it's running. If the plugs look sooty, it's too rich, if they look white it's too lean. It's just a matter of turning the adjustment nut at the bottom of the carb. Turn it in (like you would turn a screw) for lean, out for rich.
I'm afraid I can't help you with the knocking clutch (I've never had any experience with clutches), but the clevis pin is easy to check. If you put your head down near the floor and look up to where the pedal attaches to the clutch rod, you can press the pedal and and see how much movement there is between the rod and the pedal. There should only be a few mm. Worth checking, but it's more likely to be a hydralics problem - you may need to bleed the clutch cylinder (which only takes a minute anyway).
