It is currently Thu Jul 24, 2025 12:35 am
 Post subject: price advice
PostPosted: Thu Feb 03, 2011 9:18 pm
Milatsmadmini
disassembled 1360, freshly ground crank and new rods and pistons, head in pieces, no box for $500?
Would ya do it?
PostPosted: Thu Feb 03, 2011 9:23 pm
Give Ash some flowers Nick .
Yep, definitely. Even if it is a 1100S motor.
PostPosted: Thu Feb 03, 2011 9:35 pm
Seems pretty cheap! Make sure you check it thoroughly...
(if it's all good, good score!)
Jacob
PostPosted: Thu Feb 03, 2011 9:37 pm
Crack test the crank- fresh ground or not, they are all old now. :lol:
PostPosted: Thu Feb 03, 2011 9:38 pm
I'd hit it..... err buy it. :wink:
PostPosted: Fri Feb 04, 2011 5:46 am
Mods rock!
Check the bores carefully and the crank as the Doc has suggested.
PostPosted: Fri Feb 04, 2011 6:38 am
Milatsmadmini
Bores seem alright, would need a good hone. Also comes with a second block, the bores have some slight corrosion, and looks like a valve had dropped in the 2nd cylinder causing a bit of damage, but its virgin bore, so would be able to bore out to clear that up.
Ill take some pics next week see if the 2nd can be salvaged...
Ta,
Matty
PostPosted: Fri Feb 04, 2011 8:16 am
Both blocks have original caps? very important. Lots of little things will cost you $$$ if not there like primary gear, clutch cover, cam, pushrods etc etc. All adds up
Other than that sounds like a bargain. Where is it? want me to pop around to have a squiz?
PostPosted: Fri Feb 04, 2011 8:24 am
Milatsmadmini
ive got a few engines to steal parts from,
[edit] pushrods and cams are different... doh!
when crank was reground, caps were added to suit. ill see what else i can sus from him,
he's a trusted seller up in Frenches Forest.
PostPosted: Fri Feb 04, 2011 11:03 am
So long as it doesn't need tunnel boring... mismatching caps = $$$ to sort out
