Speedo Drive Gear https://www.ausmini.com/forums/viewtopic.php?f=2&t=68694 |
Author: | 76van [ Fri Feb 04, 2011 7:46 pm ] |
Post subject: | Speedo Drive Gear |
hi,can i use the speedo drive gear out of a morris 1100 remote gearbox in my clubman rod change box ? the clubman box has no drive gear in it.if not where can i get one ? thanks in advance jayson |
Author: | GT mowog [ Fri Feb 04, 2011 7:54 pm ] |
Not sure if the Morris one is the same as mini, I think it would be, however best check. The stock Oz mini ones were 17 tooth pinion and 6 tooth spindle. |
Author: | drmini in aust [ Fri Feb 04, 2011 8:12 pm ] |
Is same gear in both. Only the UK fiddled pinion gears, not Oz. ![]() We just used a heap of different speedos instead. |
Author: | 76van [ Sat Feb 05, 2011 2:22 pm ] |
thanks gt,thanks doc,just the answer i was hoping for. cheers jayson |
