It is currently Sat Aug 02, 2025 5:05 pm
PostPosted: Wed Aug 24, 2011 1:05 pm
Hi once again im after some advice and anything you can help me with would be much appreciated :).
I am about to take my mini for a road worthy check and im wondering what are the things they look for so i can fix them if need be befor it goes in?
thanks again guys :D
Regards Kermit (TadPole)
PostPosted: Wed Aug 24, 2011 1:21 pm
Brake flexible hoses - check for any cracking (probably just swap them)
Wheel cylinders - roll the dust seal back and check for fluid
Meat on brakepads/shoes, and undersized discs/oversized drums
Ball joints - I always replace them, or you could lap them and re-shim depending on condition
Shocks - any leaks usually
Seat belts - any signs of fraying or fading
Rips in seats
Fuel flexy lines
Bad oil leaks
About all I can think of at the moment.
PostPosted: Wed Aug 24, 2011 2:02 pm
thanks for the reply. most of them im sure are fine but ive still gotta check out the brakes properly and go over the lines. cheers :)
