It is currently Sat Aug 02, 2025 5:15 am
 Post subject: 1275 crank
PostPosted: Wed Feb 09, 2011 2:45 pm
striped my blown 1275 down, it has a 12g1505a crank.
is this a large journal ?
jayson
PostPosted: Wed Feb 09, 2011 2:52 pm
12G1505, 1275cc, Non-S, EN16T with 1.75" dia. big ends.
http://www.calverst.com/articles/Eng-Cr ... tionID.htm
PostPosted: Wed Feb 09, 2011 3:06 pm
^^^^ that means yes
PostPosted: Wed Feb 09, 2011 3:43 pm
thanks guys
PostPosted: Wed Feb 09, 2011 6:22 pm
Crack test before you grind it, cracking is common in these.
Of 6 big J cranks that St George Cranks got in to grind a while ago, 4 were cracked already. :cry:
 Post subject: Large journal crank.
PostPosted: Wed Feb 09, 2011 7:31 pm
Make sure that it has not been offset ground to make a stroker. Check which rods it was used with !!! Might be a stroker !!!
"Let us remove your "SHORTS"
PostPosted: Thu Feb 10, 2011 5:36 am
thanks doc,what do they do to crack test them ?
convertible mini,how do i now if it`s been strocked ? is standard bore if that helps.
jayson
PostPosted: Thu Feb 10, 2011 9:25 am
Dye penetrant crack testing, either a two stage (red dye then white powdery paint) Dye penetrates the crack, then bleeds back to show through white second coat.
http://www.twi.co.uk/content/ksijm001.html
http://en.wikipedia.org/wiki/Dye_penetrant_inspection
Or fluorscent dye penetrant, spray the crank, then look at it under fluorscent light to see where dye has penetrated crack.
http://www.marinediesels.info/repairs/c ... ection.htm
Both these techniques (I think) can be aided by magnetising the test piece to concentrate the dye into the crack.
Sir Alec! we are not worthy!
PostPosted: Thu Feb 10, 2011 10:39 am
jayson
Measure the diameter of the bigends. I'm not sure of the numbers off the top of my head but you can grind these down to accept the 'S' conrods, and if you offset grind these you can either increase or decrease the stroke of the engine. I think it's covered in Vizard's Tuning The A-Series Engine (the yellow book).
PostPosted: Thu Feb 10, 2011 3:45 pm
ahh ok,thanks guys. i have vizards book will look into it.
jayson
