It is currently Sat Jul 19, 2025 5:39 am
PostPosted: Sat Feb 12, 2011 10:31 am
the rover mini has no rear seat bealts. i assume it's the same as other models for later type retractable.
i would like to put some in.
any idea what numbers i need to go for or where i can get them new..
PostPosted: Sat Feb 12, 2011 10:41 am
Repco and all the other usual suspects have (or can get) them.
PostPosted: Sat Feb 12, 2011 10:46 am
ok i think i tracked it down
klippan k2257, im just not sure what the centre one is.
well looks like this mini does not even have mounts for rear seat belts.
PostPosted: Sat Feb 12, 2011 3:56 pm
Centre belt? Do you really want 5 seatbelts in your mini?
How old is the car? I'm not too sure about the different setups but i believe some early rovers had no fixture points, some had them for a parcel shelf style mount and the later ones had them on the C pillar.
If you do go ahead with fitting the belts, make sure you mount them properly
PostPosted: Sat Feb 12, 2011 4:14 pm
I can't even find the mounts lolif there is any. I would like some at the back
For some safety it's a fast car.
PostPosted: Sat Feb 12, 2011 4:53 pm
If it's an Oz roundnose Mini, all except the very last (in 1971) had NO rear mounts fitted by the factory.
Police issue Minis may be an exception....
Note that Clubbies had them, but their parcel shelf was reinforced for the purpose.
