It is currently Sat Jul 19, 2025 4:53 pm
PostPosted: Sun Feb 13, 2011 5:48 pm
Quick question for the knowledgeable people on here,
Does the altering of the bore size of a block stop you from using some heads?? say for example if i had a block with the capacity of 1460cc and I'm putting an alloy 7 port head onto it does the head need to be changed. Hypothetically speaking could i put a stock 1275 head on a 1460?
Thanks,
Bill
PostPosted: Sun Feb 13, 2011 5:50 pm
Sure you could, but check the C/R, you may need to rip the chambers out to a bit bigger volume with ye olde die grinder. :wink:
PostPosted: Sun Feb 13, 2011 8:06 pm
cool cheers.
Bill
PostPosted: Mon Feb 14, 2011 8:14 am
What a stupid question Bill, Maybe you should stick to motor bikes :D
