gasket goo on oil pump gasket? https://www.ausmini.com/forums/viewtopic.php?f=2&t=68835 |
Author: | simon k [ Sun Feb 13, 2011 1:59 pm ] |
Post subject: | gasket goo on oil pump gasket? |
I'm putting my motor together - I've never put gasket goo on the oil pump gasket, but I think I read somewhere that some people do it... advice from the gurus? |
Author: | GT mowog [ Sun Feb 13, 2011 2:07 pm ] |
If it is an ordinary paper gasket (without some rubbish coating) then it shouldn't matter either way. I usually do use goo just to be sure. |
Author: | Mick [ Sun Feb 13, 2011 4:06 pm ] |
I'm not a fan of silicone gasket stuffs here, in case a squeezed out bead gets into the oilway, but I like a bit of Loctite No.3.. It costs nothing... |
Author: | drmini in aust [ Sun Feb 13, 2011 5:42 pm ] |
Mick wrote: I'm not a fan of silicone gasket stuffs here, in case a squeezed out bead gets into the oilway, but I like a bit of Loctite No.3..
It costs nothing... Me too. ![]() |
Author: | Morris 1100 [ Sun Feb 13, 2011 5:44 pm ] |
drmini in aust wrote: Mick wrote: I'm not a fan of silicone gasket stuffs here, in case a squeezed out bead gets into the oilway, but I like a bit of Loctite No.3.. It costs nothing... Me too. ![]() Yep, number 3 for me too. |
Author: | simon k [ Sun Feb 13, 2011 6:36 pm ] |
thanks guys I can never find my little bottle of #3... it blends in with all the other black gooey things in my garage |
Author: | Timbo [ Sun Feb 13, 2011 7:10 pm ] |
I don't use anything, even if it leaks it won't lose much and a small oil leak on the inside of the engine doesn't matter. Tim |
Author: | Morris 1100 [ Sun Feb 13, 2011 8:10 pm ] |
Timbo wrote: I don't use anything, even if it leaks it won't lose much and a small oil leak on the inside of the engine doesn't matter.
Tim If it leaks on the suction side it may get an air lock in the pump when it is parked. If it leaks on the pressure side it will reduce the available pressure. Either way it won't matter. ![]() |
Author: | VulcanBB18 [ Mon Feb 14, 2011 4:14 pm ] |
Never used any goop on the oil pump gasket, just made sure both surfaces are spotless. Never had any oil pressure issues... cheers Jacob |
Author: | brisgt [ Tue Feb 15, 2011 8:02 pm ] |
Post subject: | oil pump gasket goo |
Just another idea you could use some avaiation gasket goo/ permatex i found it to work well on all paper gaskets but as the other have said use it sparingly as you dont want to squish the excess out everywhere and possibly interfer with anything wade |
Author: | drmini in aust [ Tue Feb 15, 2011 9:14 pm ] |
Permatex #3 aviation cement is now called Loctite #3. Same stuff in the same bottle with the same brush. ![]() |
