Need help
https://www.ausmini.com/forums/viewtopic.php?f=2&t=68891
Author:  MiniDna [ Wed Feb 16, 2011 7:02 pm ]
Post subject:  Need help
Hi all,
Every time I drive when it is raining dissy(it is a electronic pulsar One) gets water and car straggles under acceleration from stand still.
I get out spray with WD 40 from outside and couple of minutes later it is fine till next rain.
I do have the plastic cover behind the grill but doesn`t seem to be working properly.
Has anyone got better idea; like covering the hole dissy with hard plastic bags or something?
Author:  drmini in aust [ Wed Feb 16, 2011 7:18 pm ]
I also run a Pulsar dizzy.
Mine was like that until I fitted new plug leads. Top Gun etc cheap ones only are good for a year or two, then they can break down.
Since fitting Bosch leads (from Supercrap) 4 years ago I can hose the engine while running, dizzy cap included.. :P
Author:  Morris 1100 [ Wed Feb 16, 2011 7:29 pm ]
I would be cleaning off all the residual WD40 and other gunk off the cap and leads as well as checking resistance of the leads.
I run a Pulsar dizzy too and don't worry at all about hosing the engine to degrease it.
Author:  MiniDna [ Wed Feb 16, 2011 7:30 pm ]
Thanks drmini.
I will do that tomorrow.
Author:  Super-mini [ Wed Feb 16, 2011 7:58 pm ]
its usually the leads +1
Author:  Mini_Maxx [ Wed Feb 16, 2011 8:01 pm ]
Yup, what Supermini said. LEADS
Author:  GT mowog [ Wed Feb 16, 2011 8:06 pm ]
Doesn't these caps also have an O ring?
Author:  Morris 1100 [ Wed Feb 16, 2011 8:08 pm ]
When I lived in the Blue Mountains (on a good day you can see fog) I found that it was usually the grime and oil on the outside of the cap that caused the spark to go astray when it was wet.
Start the car on a dark night, apply water and you will see where the sparks jump. :lol:
Author:  gafmo [ Wed Feb 16, 2011 8:12 pm ]
nice Tip Morris
Author:  GT mowog [ Wed Feb 16, 2011 8:18 pm ]
Although I mentioned the O ring, I suggested it as something else to look at. I agree that the leads and the boots on the leads are the most likely cause, which in turn is probably from the WD-40, it rots rubber, doesn't do silicone any good either. It will also work better in the rain if you spray a little on before you venture out, but best clean it off as soon as is possible. There is one of them Water Displacing sprays that is better than the others in that it does not rot rubber. CRC 3-35?
Author:  drmini in aust [ Wed Feb 16, 2011 8:27 pm ]
Back in the good old days (pre- WD40) we used silicone dielectric grease, smeared on. It was wonderful... 8)
Author:  MiniDna [ Wed Feb 16, 2011 9:14 pm ]
Thanks guys. I will get new set of leads tomorrow and double check the O ring too.
