Brightening carbs https://www.ausmini.com/forums/viewtopic.php?f=2&t=68937 |
Page 1 of 2 |
Author: | bmacpiper [ Fri Feb 18, 2011 5:25 pm ] |
Post subject: | Brightening carbs |
Hi all, Soaked my disassembled SU's in Simple Green for a couple of days, and all old residue is gone. However, they are now a dull dark greyish color, i.e. like oxidized aluminum. Is there a product that will easily remove oxidation and brighten them up again? tx, bmc |
Author: | MG Rocket [ Fri Feb 18, 2011 8:08 pm ] |
I think you will have to just buff them for best results Once you have done that there is a coating you can put on them. http://www.sharkhidesalesaustralia.com.au/ ![]() Here is a fishing forum with many boaties with many questions about the product. ![]() edit> forgot to put in link ![]() http://www.ifish.net/board/archive/inde ... 96978.html |
Author: | 1018cc [ Fri Feb 18, 2011 9:15 pm ] |
You can always send a PM to 'gafmo', he likes to buff. I heard a while back the POR make a clear coat that stays clear (the same people that make POR15). |
Author: | 1310/71 [ Fri Feb 18, 2011 9:18 pm ] |
1018cc wrote: You can always send a PM to 'gafmo', he likes to buff.
I heard a while back the POR make a clear coat that stays clear (the same people that make POR15). PPC I think their name is = Permanent Protective Coatings (or something similar). |
Author: | 1018cc [ Fri Feb 18, 2011 9:24 pm ] |
Thanks 1310/71, out of interest I just went and found the link and you are spot on: http://www.por15.com/GLISTEN-PC/productinfo/GPCGG/ (although it doesn't say PPC on that page). |
Author: | bmacpiper [ Sat Feb 19, 2011 4:02 am ] |
Thanks for the tips. Looks like both products/companies are US-based, so I'm sure I can find them here. bmc |
Author: | gafmo [ Sat Feb 19, 2011 7:18 am ] |
It looks like the Simple Green has done the job in getting the Years of grime from your carb. I don't know a product that would take the tarnish off it other than a bit of elbow greece. Any of the popular metal polish will do the job just depends on the amount of time and effet you want to take. You can try anything from Brasso to Autosol to give the shine back. I would test them on the bottom of the carb first and see how much time it would take to get the result you want. You can go to the other extreme and and take many hours and take every scratch & mark out with various grads of wet & dry and buffing wheels http://forum.caswellplating.com/ I also use POR Glisten I have used it on many parts and the motor in my Van is not painted a colour but brushed Glisten for that raw look |
Author: | GT mowog [ Sat Feb 19, 2011 7:25 am ] |
http://ppcco.com.au/ Their technical help is very good, however it is only valid if you follow their instructions exactly / to the letter. These guys sell it http://wwwvgautopaints.rtrk.com.au/ |
Author: | Mick [ Sat Feb 19, 2011 10:27 am ] |
glass/plastic bead/soda blast? before: http://i6.photobucket.com/albums/y223/A ... C03035.jpg after: http://i6.photobucket.com/albums/y223/A ... C02318.jpg |
Author: | Phat Kat [ Sat Feb 19, 2011 11:08 am ] |
Mick wrote: glass/plastic bead/soda blast?
before: http://i6.photobucket.com/albums/y223/A ... C03035.jpg after: http://i6.photobucket.com/albums/y223/A ... C02318.jpg Only problem you'll find with blasting Ally, is that it gets dirty very quickly afterwards. I personally don't mind the finish, I find it quiet attractive, but if ANYTHING even thinners touches it, you'll see a discolouration. In that regard its a bit of a pain in the arse. As gaf said... elbow grease, no substitute for sweat. |
Author: | Mick [ Sat Feb 19, 2011 5:40 pm ] |
I have been watching that on my set as I have been watching the weathering on the engine paint, zinc plated and bare surfaces since resto. I haven't found it to be a problem in the two years so far. I don't use mine as a daily however, but I think the the glass polishes more than it etches which stops oils from soaking into the metal. I think it was 850man who mentioned a method of returning them to a seemingly more original die cast finish. I can't find the post however... |
Author: | Daren W [ Sat Feb 19, 2011 6:45 pm ] |
blast using crushed walnut Regards Daren |
Author: | Morris 1100 [ Sat Feb 19, 2011 7:00 pm ] |
Polish with teabags. |
Author: | 1310/71 [ Sat Feb 19, 2011 7:32 pm ] |
Morris 1100 wrote: Polish with teabags.
teabag it? I think you've been looking at the wrong websites. ![]() |
Author: | brett [ Sat Feb 19, 2011 10:50 pm ] |
Or Big Brother! |
