It is currently Fri Jul 18, 2025 12:36 pm
 Post subject: timing
PostPosted: Sat May 29, 2004 4:05 pm
just wondering what the timing should be set to on my mini?
does it make a difference if a have a different cam?
PostPosted: Sat May 29, 2004 11:23 pm
Ohhhh Kayyy, did you happen to get one of those fancy vernier disks with the cam? :roll:
PostPosted: Sat May 29, 2004 11:33 pm
i have timed mini's at 6* adv but on the other hand have timed mini's at 23* adv. all depends on eng mods and cam....cam is good.
go stop...go..stop..go. stop..go...stop...Damn malls are crowded
PostPosted: Sun May 30, 2004 12:47 pm
the egine specs is
1100cc (+40thou rebore)
camtech 631 cam
extractor
sports exhaust
1 1/2 su
it ran really smothlty until the dizzy got turned around abit, (opps)
whats the standered timing ment to be? il start at that and see how i go
cheeers
PostPosted: Sun May 30, 2004 6:32 pm
I would probebly start at around 8* adv....But the cam you mentioned may work or respond a little better around 12*adv
PostPosted: Sun May 30, 2004 6:41 pm
I've got a Camtech 631 in a 1098 with BIG valved head, LCB, blah blah... it runs good at 10* BTDC static timing.
A lot will depend on what weights and advance plate are in the dizzy though (or what dizzy...!). I'd set it at 10*, try it out, then advance a few degrees more. If it pings put it back... :P
Max advance it gets to when thrashed is more important than the static setting. :wink:
