It is currently Fri Jul 18, 2025 7:03 pm
 Post subject: K&N 1.3i Air Filters
PostPosted: Sat Feb 26, 2011 5:16 pm
Die Die Die!!
i have a 1.3 injected A+ Rover and ive fitted a K&N Filter to it but it doesnt like to stay on.. keeps slipping off.. how have people remedied the situation ?
Nick
PostPosted: Sat Feb 26, 2011 5:35 pm
Stock airbox with K&N inside.
:D
PostPosted: Sat Feb 26, 2011 5:38 pm
Die Die Die!!
wouldnt the pod give you more power though ?
PostPosted: Sat Feb 26, 2011 5:43 pm
Debatable.
I run the stock box because it looks better and it won't be sucking in (as much) hot air, whereas a pod filter does.
Really,on an engine only kicking out about 45 hp what's it matter?
PostPosted: Tue Mar 01, 2011 1:46 pm
Tighten up the clamp.
That filter fell off so many bloody times straight after I put it on because I didn't have it on square and done up tight enough.
It's a crap to do up properly, but once it's done it won't fall off.
And, that car runs better with that filter.
PostPosted: Tue Mar 01, 2011 1:51 pm
What sort of clamp is it?
Odd as it may seem, if the clamp is too wide it could be helping the thing come off.
PostPosted: Tue Mar 01, 2011 1:55 pm
big ass one of these -
I reckon a narrower clamp would solve the problem.
PostPosted: Tue Mar 01, 2011 3:02 pm
Supercharged
k&n within the stock box, pods dont work without cold air intake.
PostPosted: Tue Mar 01, 2011 3:27 pm
people only think pods work because they make more noise...
PostPosted: Tue Mar 01, 2011 4:43 pm
Die Die Die!!
yeah ive got one of them.. but it slips off the neck of the intake
PostPosted: Tue Mar 01, 2011 7:16 pm
opposite, tested on the dyno. make good sounds tho.
