distributor leads position https://www.ausmini.com/forums/viewtopic.php?f=2&t=69177 |
Author: | aussie [ Wed Mar 02, 2011 5:17 pm ] |
Post subject: | distributor leads position |
can someone please post me a good pic of leads coming out of the distributor and which cylinders they lead to. much appreciated. |
Author: | awdmoke [ Wed Mar 02, 2011 5:23 pm ] |
Starting at 2 o'clock on the dizzy & going anticlockwise 1-3-4-2 with 1 being the radiator end. |
Author: | mini_mad_matt [ Wed Mar 02, 2011 6:22 pm ] |
That is of course if the distributor is in the "right" spot. |
Author: | Morris 1100 [ Wed Mar 02, 2011 6:50 pm ] |
mini_mad_matt wrote: That is of course if the distributor is in the "right" spot.
And if it is not in the right spot don't, what ever you do, don't try to remove the distributor drive and drop it into the sump. |
Author: | Mini_Maxx [ Wed Mar 02, 2011 6:53 pm ] |
Morris 1100 wrote: And if it is not in the right spot don't, what ever you do, don't try to remove the distributor drive and drop it into the sump.
That made me throw tools everywhere ![]() |
Author: | jethro [ Wed Mar 02, 2011 8:48 pm ] |
unless you screw a long 5/16 unf bolt in first |
Author: | Fat Boy Dave [ Wed Mar 02, 2011 9:24 pm ] |
Magnet on telescopic rob works a treat ![]() |
Author: | Morris 1100 [ Thu Mar 03, 2011 4:18 pm ] |
There is no real need to remove it if it has been fitted wrong. Just stick the leads where they need to be and not where they are supposed to be and it will all work perfectly. |
Author: | Mike_Byron [ Thu Mar 03, 2011 6:03 pm ] |
A couple of yers back i wrote a very long treatise on how to set up the timing on a mini. It was from the distributor drive, getting top dead center, aligning the distributor and the n positioning the leads. I dont have the band width (flakey satellite internet) to search for it but if someone else can it may help here. It certainly mentions the ways to avoid dropping the drive into the sump. Mike |
