Engine color, again . https://www.ausmini.com/forums/viewtopic.php?f=2&t=69212 |
Author: | austin costin [ Fri Mar 04, 2011 12:45 pm ] |
Post subject: | Engine color, again . |
SORRY, I know that this has been asked a thousand times, I did trawl through the pages but was un able to find the last link. I am after the met green met color, I went to the local Bunnings but as mentioned before they only have the forest green in hammer finish. I also drew a blank with the color codes that were listed. Someone mentioned that there was a Saab color that was almost identical! OR a modern color code that I can use here in NZ. Cheers Paul. ![]() |
Author: | Anto [ Fri Mar 04, 2011 2:17 pm ] |
Alpine green hammer finish from Bunnings is what I used. They should be able to order it if they don't have it on the shelf. |
Author: | kiwiinwgtn [ Fri Mar 04, 2011 7:24 pm ] |
Hi Paul The paints etc in Bunnings NZ and Bunnings OZ are different as they are sourced from different suppliers I lived in both countries, there is way more stuff avaliable in OZ Try this company Union Hardware (1998) 236 Riddiford Street Newtown 6021 (04) 389 3064 They have been around for many years and specalise in Automotive paints. Cheers Bernard |
Author: | austin costin [ Sat Mar 05, 2011 7:27 am ] |
Dont want to use the hammer finish as its not origional but will need color code to order from a supplier ![]() ![]() |
Author: | Goldbrocade_62 [ Sat Mar 05, 2011 10:13 am ] |
I use a Saab colour it is called mozelle green it may be called another name in NZ it is close but not 100% |
Author: | austin costin [ Tue Mar 08, 2011 5:06 pm ] |
Any more details/codes, all are welcome ![]() |
Author: | drmini in aust [ Tue Mar 08, 2011 6:52 pm ] |
Mini King has the various correct engine paint colours available in 1L? tins. Not sure if this helps- as there may be issues freighting paint to UnZud.. |
Author: | phillb [ Tue Mar 08, 2011 8:37 pm ] |
drmini in aust wrote: Mini King has the various correct engine paint colours available in 1L? tins.
Not sure if this helps- as there may be issues freighting paint to UnZud.. I agree with Doc, Miniking paint is correct colour and very good quality. I'm usually crap at painting but it turned out excellent. (see pic below) Even did it with the engine in the car. Because it's metallic it's better to spray so I used a prevel unit see http://www.preval.com/shopping/val-pak If you can work out a way of getting it shipped then that would be the way to go. ![]() |
