It is currently Wed Jul 23, 2025 11:08 pm
PostPosted: Wed Feb 23, 2011 6:00 pm
Top right as in this picture.
This is from a 'rebuilt' engine. Should I consider a new flywheel housing?
PostPosted: Wed Feb 23, 2011 6:08 pm
Nah get a shop to grind it back, fill it up with weld then cut it back to a flat face.
Shouldn't cost too much.
Or if you really cannot be bothered, go grab a new housing :lol:
PostPosted: Wed Feb 23, 2011 6:17 pm
I don't have a shortage of second hand spares, however i'd need to get a new bearing and seal?
PostPosted: Wed Feb 23, 2011 6:18 pm
To do it properly, yes you definitely would.
The last thing you want is a leaking primary seal.
Or a grumbly drop gear bearing.
PostPosted: Wed Feb 23, 2011 6:22 pm
I shouldn't have pulled it off. Ignorance is bliss. :lol:
PostPosted: Wed Feb 23, 2011 6:32 pm
There was an oil seal thread in here last year-
There are 3 clutch seals available:
1. The common red one that everybody sells here, they are cheap rubbish now, made wherever.
They leak, much too soon (like, @8000 miles). And, the springs fall off em too. Want any? I'll post ya a couple to be rid of em.
2. The black Rover seal, dearer but a much better seal. Available from Karcraft etc.
3. The red `competition' Gaco seal (this was the std red one we got here years ago). Best, IMO. Available from Lindsay Seibler, or bring in from Minispares UK.
PostPosted: Wed Feb 23, 2011 6:55 pm
Is the crack just across the machined face or does it go further down?
If you couldn't be bothered doing it willy's way and don't want to use another case, you can buy that liquid metal stuff that sets hard and just file it flat. Or if your a cheap ass, just get some epoxy resin and smear some around the crack to seal it, and use some goo on the gasket.
PostPosted: Wed Feb 23, 2011 7:05 pm
It doesn't go much further than what you see...
PostPosted: Wed Feb 23, 2011 7:07 pm
This space for rent
I'd be tempted to file it out and fill with that metal epoxy mentioned above...
PostPosted: Wed Feb 23, 2011 7:15 pm
Yup, file or hacksaw to the full depth of the crack and devcon (or whatever your favourite epoxy is) fill it. File flat.
PostPosted: Wed Feb 23, 2011 9:36 pm
Poeee ditch it. The roller brg is about $28 the needle is about $12 and a seal is about $8[ good vitron type] I get all these from A.W.B. bearings ,so I sure that there is a place ic Vic.
Now as for a replacement case[a 4 syncro type ] I will send you one that has been all nicely soda blasted for a belated wedding present.
Do not stuff around with it ,it's not worth stuffing a re-build for that cost.
Just send me a PM with details and I will get it done over the week end and stick in the mail to you.
www.minisprintgt.com
PostPosted: Thu Feb 24, 2011 8:10 am
Who said marriage and Minis don't go together? Nice one David :D
the internet wrote:
Like Audrey Hepburn, almost everybody loves the Mini. The only people who didn't love the Mini were pathetic, empty people.
PostPosted: Thu Feb 24, 2011 10:26 am
Now's there's an offer to good to refuse! 8)
PostPosted: Thu Feb 24, 2011 12:54 pm
Cheers buddy, you're a champ.
PostPosted: Sat Mar 05, 2011 7:57 pm
What are the part numbers for the two bearings that sit in the clutch housing?
