It is currently Fri Jul 25, 2025 11:41 pm
 Post subject: Hiff44 cable help
PostPosted: Fri Mar 04, 2011 6:32 pm
Can't make this work to tune it.. Anyhelp??
PostPosted: Fri Mar 04, 2011 7:21 pm
I am not sure what you mean - however - I run a HIF and I found it simpler to source the mounting bracket and a new correct throttle cable.
I got them off ebay via england and they came within a week.
This was a few years ago now and they may be available locally now.
Mike
PostPosted: Fri Mar 04, 2011 7:31 pm
Swapped the linkage to the passenger side it works :)
they are a tight fit with a mini spares manifold??? mine just misses the firewall.
im over twin su's mine likes to go out of balance, i have wanted a single hiff44 for ages so i bought one bolted it on & getting it tuned.
see if it makes more power or the same or less.
anyone got idea with the choke cable?
