crankshaft pulley bolt https://www.ausmini.com/forums/viewtopic.php?f=2&t=69233 |
Author: | jethro [ Sat Mar 05, 2011 4:40 pm ] |
Post subject: | crankshaft pulley bolt |
Hi Guys, I`ve just put my timing cover back on and also my crankshaft pulley bolt. According to the gregories manual the bolt needs to be torqued to 70 lbs ft, I think it is. How do you stop the crankshaft from turning as you tighten the bolt ?? Jethro |
Author: | superSeven [ Sat Mar 05, 2011 5:09 pm ] |
Post subject: | Re: crankshaft pulley bolt |
jethro wrote: Hi Guys, I`ve just put my timing cover back on and also my crankshaft pulley bolt. According to the gregories manual the bolt needs to be torqued to 70 lbs ft, I think it is. How do you stop the crankshaft from turning as you tighten the bolt ??
Jethro I have a piece of fly wheel ring gear cut to size to fit in the starter motor hole, drilled with a bolt through the side. put this in so the ring gear teeth mesh, so the fly wheel turns, the bolt hits the casing, no more turny turny.. ![]() |
Author: | drmini in aust [ Sat Mar 05, 2011 5:42 pm ] |
Just sit an old main bearing shell in the ring gear, in the starter hole. It won't slip. Otherwise, get your sexy (or not) assistant to hold a BF screwdriver in the ring gear... firmly. ![]() |
Author: | Mini_Maxx [ Sat Mar 05, 2011 6:11 pm ] |
Big ass screwdriver works a treat ![]() |
Author: | jethro [ Sun Mar 06, 2011 11:31 am ] |
big screwdriver sound good. Thanks guys. |
