It is currently Sun Jul 20, 2025 1:16 am
PostPosted: Sun Mar 06, 2011 4:49 pm
Rover Cooper
88 rover mini, with the works.
:shock: :shock:
Don't laugh I can do it on most cars but never tackled it on a mini, just incase there is a secret that I am not sure of, advice and some pics pleease.. :roll: :roll:
Might do the back drum brakes as well,prevention is better than cure..LOL.. :wink:
PostPosted: Sun Mar 06, 2011 5:00 pm
Wheel off,
split pins out,
slide pads out,
new pads in,
new split pins in,
wheel on.
test.
:lol:
PostPosted: Sun Mar 06, 2011 5:12 pm
Give Ash some flowers Nick .
willy, you forgot the 'jack car up - safely' and 'push pistons back into caliper' step :P
Davo, should be easy mate :wink: The back brakes tend to wear quite a bit slower than the front ones - just check to see that they actually need doing before you just waste your money.
PostPosted: Sun Mar 06, 2011 8:46 pm
you'll laugh when you take the wheel off and have a look - nothing could be simpler :lol:
PostPosted: Sun Mar 06, 2011 8:49 pm
If ya struggle... bring it down here for a spin and i'll give ya a hand.
PostPosted: Sun Mar 06, 2011 9:15 pm
You should measure the disc rotors for thickness too, and replace them with the new pads if they're getting close to the limit.
PostPosted: Mon Mar 07, 2011 10:16 am
Rover Cooper
Thanks Gents, 2 out of 3 aint bad...LOL.... :oops: :oops: :oops:
