It is currently Sun Jul 20, 2025 11:56 am
 Post subject: van rear door seals
PostPosted: Thu Mar 10, 2011 7:07 am
Hey everyone, so previously I tried to put some new rear van door rubber seals in. I failed dismally and once installed the doors wouldn't shut! In the end I gave up and removed the bottom and outside portion on one side. I have just got some more and some clips. What is the secret? Any tips would be appreciated hugely.
I think the lack of seal has something to do with my exhaust smell problem. [/quote]
 Post subject: Referral
PostPosted: Thu Mar 10, 2011 11:05 am
Best you go to the Horses mouth
Call: Mackay Consolidated
Head Office, Engineering & Manufacturing
260 Chesterville Road
PO Box 1113
Moorabbin
Victoria 3189
Australia
Telephone +61 3 9555 6500
Facsimile +61 3 9276 8882
and talk to them, they will know the tricks and tips.
They even have a host of part numbers for the mini range.
http://www.mackayrubber.com.au/all-catalogues.htm
Let me know how you go as I have this same issue ahead of me.
Good luck
PostPosted: Thu Mar 10, 2011 7:43 pm
would like to hear any advice as well,this is one of the next jobs on my list
 Post subject: Re: Referral
PostPosted: Thu Mar 10, 2011 7:48 pm
PO Box 1113
Moorabbin
Victoria 3189
Australia
Good luck
Didn't know / think that Mackay did door rubbers, only hoses and mounts. Could find it in their catalogues. It has always been the likes of Spectrum that have done the door type rubbers.
PostPosted: Thu Mar 10, 2011 8:33 pm
also very interested in this topic as Marcia is about to be on the road with minimal seals on the rear doors
PostPosted: Fri Mar 11, 2011 11:24 am
I was secretly hoping that you would have already have done this Gafmo.
I might have a crack tomorrow and see how i go.
David
PostPosted: Fri Mar 11, 2011 12:35 pm
What are the new seals like? I have a set form Minisport in the UK, which is different to the original profile in that it doesn't have a little groove for the original clips to hook into, so I'll try that "body mounting" tape they sell in Supercheap, unless anyone has a better idea?
PostPosted: Fri Mar 11, 2011 7:52 pm
Sorry David. its amazing what you go to get a car on the road but you forget a number of things. Its a wake up when you go for the first real drive to get a blue slip and they slap around worse than a Dunny door.
Its a must for me also
PostPosted: Sat Mar 12, 2011 5:03 am
just went and had a look at my strips and they are the same as angus mentioned without the lip. Will make a tip to supercheap and let you know how I go people.
Gafmo
It's not good enough. lift your game! :) :)
PostPosted: Sun Mar 20, 2011 7:52 pm
Floss any additional info by chance
PostPosted: Sat Aug 27, 2011 10:01 am
Thread revival. I finally got my rear door rubbers from KC
How did you guys attach the rubbers on?
PostPosted: Sat Aug 27, 2011 9:12 pm
next job on my list as well
PostPosted: Sat Aug 27, 2011 9:16 pm
hey gaf any more bling updates. i miss the shinney
PostPosted: Sat Aug 27, 2011 9:37 pm
no..Finishing a friends rocker cover but haven't had much time of late. Just gave my Austin Grill for Marcia a once over for tomorrow. I have had my HIF44 blasted and look brilliant, but will only do the Dashpot in the next few months
PostPosted: Sat Aug 27, 2011 9:39 pm
Any ideas about the rubbers, Sikaflex or Quick Grip
