Thanks GT, but isn't that timeline in regards to how to wait until you put your filler over the top?
adamstuart wrote:
If i'm using etch primer on bare metal, but not using any spray putty;
How long do i need to leave the etch to shrink back before i lay colour on?
Or am i mixing up terms here, when i said not using spray putty, i meant not using surfacer.
miniDave wrote:
Adam - Don't put your colour directly over etch.
After your etch has been on for an hour you need to put on primer or primer/filler. If it is the next day then lightly rub the etch with a red scouring pad. The primer when rubbed flat will give you the base for the colour.
Etch just seals the surface and is only a light coat - it won't provide any build material. Opinions vary but I put on an etch, 2 coats of primer/filler, sand with 320 dry, then 2 coats of primer/filler and then wet rub with 800 grit, then the colour.
It is worth taking the extra steps because what looks good on the colour is only as good as what is underneath.
Thanks Dave, so primer filler is a bit of a must?
Was hoping there was a quicker way around it, as the filler needs a few days to shrink back (and time is of the essence right now)
Guess i'll have to just make time. Cheers dave
