Fuel tank & Rear arm
https://www.ausmini.com/forums/viewtopic.php?f=2&t=69495
Author:  Fiji [ Wed Mar 16, 2011 6:53 pm ]
Post subject:  Fuel tank & Rear arm
Will be taking out the fuel tank this weekend due to needing to replace the rear trailing arm. (have shocks)
It has to be a quick out and back in job need the car on sunday. I wanted to treat the inside of the tank but I don't think I'll be able to get that done so just going to check for any pinhole leaks while it's out.
I'm not expecting it to b more than a few beers later just in time for Friday night footy. Are there any bushes etc I should replace whilst doing this?[/list]
Author:  simon k [ Wed Mar 16, 2011 7:10 pm ]
I have my tanks out and am just about to go out to the garage and replace the rear subframe mount rubbers.... the ones in there are 40 years old
Author:  Fiji [ Wed Mar 16, 2011 9:00 pm ]
Post subject:  .
Might have to add to the list. Could that b done fairly easily?
Put rear on stands... Unbolt subframe lower with trolley jack ... Replace rubbers bolt back up??
Author:  simon k [ Thu Mar 17, 2011 9:42 am ]
Post subject:  Re: .
about 5 minutes per side...
do it one side at a time, don't let the whole subframe down. Put your axle stands under the body in front of the subframe
Just undo the bolts through the boot, and the big nut on the stub poking out from the subframe and put a pry bar between the subframe and the body and lever it down enough to pull the mount thingy out.
new v's old, I did the front ones a couple of years ago, you should have seen them...
