It is currently Fri Jul 18, 2025 9:49 am
 Post subject: Wheel cylinders
PostPosted: Fri Mar 18, 2011 4:25 pm
What sort of life would u expect from rear wheel cylinders? [/img]
PostPosted: Fri Mar 18, 2011 4:35 pm
Mods rock!
If the fluid was fresh when installed and then changed around every year there after, I'd expect 10 years +.
If however, the routine service is overlooked, then as little as a couple of years.
Remember that Brake Fluid is hydroscopic and so will absorb moisture.
<EDIT> Mind you, many years ago there were some cheap ones getting about that leaked within days of being fitted. Rubbish seals on them.
PostPosted: Fri Mar 18, 2011 8:34 pm
I had 2 `Brake Equipment' 5/8 rear ones leak recently, 6 months apart but each 12 months old- were OK after I fitted new seals to em.
