It is currently Mon Jul 28, 2025 10:09 am
 Post subject: Moke Hard Top Roof
PostPosted: Thu Mar 17, 2011 12:57 pm
OK I am finally (hopefully) picking up my hard top roof on the weekend.
Does anyone know how it attaches to the body of the Moke??
I cant remember seeing any latches or tie downs or anything.
Does anyone have any pics of the inside of a Moke hard top??
PostPosted: Thu Mar 17, 2011 1:59 pm
What make is it? The factory Leyland ones bolt on through big holes you drill in the body. This makes them too much hassle to ever remove again and you now own a smellier, leakier, noisier version of the Mini.
Tim (self appointed hard top policeman on the Moke forum)
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Thu Mar 17, 2011 2:35 pm
I have had two hard-tops - one a home-made effort and the other built by Bronco Canopies.
Both very cleverly attached using those hooks that screw together - I'm not sure what they are called, but you have two hooked bolts with a large threaded spindle in the centre so that as you turn it it pulls the two bolts closer together - which attached to the mounting brackets for the standard hood-bows.
There was also a pair of small brackets at the front which attached to the windscreen frame with a couple of self-tappers. The home-made unit used two of the same holes as the sun-visors, but can't remember about the Bronco canopy.
I then used copious amounts of silicon sealer (non-acetic cure type) to completely seal around the joins. It worked very effectively.
All that being said, I much prefer a soft-top on the Moke.
Watto.
:shock:
PostPosted: Thu Mar 17, 2011 3:14 pm
Watto.
:shock:
Watto, these are `turnbuckles'. :wink:
PostPosted: Thu Mar 17, 2011 3:22 pm
Hey - that's them.
I just couldn't place the name in my head.
My brain is so full of useless information that the important stuff just oozes out my ears!!
Watto.
PostPosted: Thu Mar 17, 2011 4:02 pm
Thanks guys
Will have to have a closer look at it. I did have some pics but lost my phone and the roof is in Newcastle...
I was hoping to make something that will allow it to be removable.
I much prefer no roof, but for some reason I have always wanted a hard top for her. :oops:
PostPosted: Thu Mar 17, 2011 4:26 pm
The beauty of the turnbuckles was that it was easy to remove the roof (when I had the home-made one on my Moke), but on the wife's Moke the Bronco roof was a semi-permanent feature because of all the silicone.
If your roof has good seals, then the turn-buckles (assuming that's what it has or you can modify it to take them) should keep out most of the weather in wnter, and still allow it to be removable.
By the way, what year is your Moke? If it is before 1980 it can be annoying filling a top-fill tank with a hard-top (speaking from experience) and you will get a lot more petrol fumes in the car. If it is a side-fill, so much the better.
Good luck.
Watto.
PostPosted: Thu Mar 17, 2011 7:15 pm
Even if its firmly attached to the body there's still a good chance that it will rattly badly where it rests on the top of the windscreen frame. There is a lot of body twist in a Moke and its at its greatest at the top of the windscreen. The one that came with my moke was terrible on rough roads.
1955 BSA C11G
1969 Triumph TR6R
PostPosted: Thu Mar 17, 2011 7:17 pm
Milatsmadmini
You should totally scrap the idea of a hardtop...
:lol:
PostPosted: Thu Mar 17, 2011 7:41 pm
I was at the Sydney Motor Show in 1980 looking at the Mokes on display in the Leyland Pavilion (in the old Sydney Showground)
The cute blonde girl in the tight Leyland T-shirt and tight jeans handed me a brochure for the Moke and I was chatting away nicely to her about Mokes when I asked about the optional hardtop...
She lifted he nose in the air and said "a Moke should never have a roof" turned around and walked away.
This is a pick of my "hardie"
The wife says it's got to go,we prefer to go topless-so if anyone wants a hardie,let me know :) -Free to a good home!
PostPosted: Thu Mar 17, 2011 7:44 pm
Milatsmadmini
Yeh she did!
:lol:
PostPosted: Thu Mar 17, 2011 8:06 pm
The hardtop on my moke attaches to the pivot brackets for the hood bows on a soft top and at the back with clips that lock under the rolled edge of the back. No extra holes! 8)
My moke has never had a softtop from new! :shock:
PostPosted: Fri Mar 18, 2011 8:03 am
Bugger I didnt think about that.... :oops:
Thanks for the pic... helps me understand how to get this thing on. Mine looks similar to that one but mine has sliding back windows from memory.
Interestingly, the filler tube is a long way back on your top for a top mount fill Moke.
mattsmadmini wrote:
You should totally scrap the idea of a hardtop... :lol:
You should stop picking on people and get your moke back on the road.......!!!!
PostPosted: Fri Mar 18, 2011 8:53 am
This top has a "Leyland" logo stamped in it near the filler hole,and should suit the early model Moke with side filler.Has a lockable liftup rear hatch and lockable side doors.
Users browsing this forum: Bing [Bot] and 75 guests
