Thermostat Housing https://www.ausmini.com/forums/viewtopic.php?f=2&t=69525 |
Author: | tracytracey [ Thu Mar 17, 2011 7:34 pm ] |
Post subject: | Thermostat Housing |
Sorry if this is a stupid question, but is there a difference between forward and rear facing thermostat housings or can you just change the way it faces? Cheers. |
Author: | GT mowog [ Thu Mar 17, 2011 7:37 pm ] |
You mean between early Mini and Late Clubmans / Mokes? Yes, they are different and even the rear facing small bore is different to the rear facing big bore. |
Author: | justminis [ Thu Mar 17, 2011 8:21 pm ] |
The 3 studs (or bolts) that secure the thermo housing are not eqi-distant, meaning that whatever housing you have only goes on 1 way. You can change the rear facing housing to a front facing housing by using the proper housing and the associated radiator, top hose and top rad bracket. Hope that answers your question. |
