Wheel cylinders https://www.ausmini.com/forums/viewtopic.php?f=2&t=69545 |
Author: | Fiji [ Fri Mar 18, 2011 4:25 pm ] |
Post subject: | Wheel cylinders |
What sort of life would u expect from rear wheel cylinders? [/img] |
Author: | GT mowog [ Fri Mar 18, 2011 4:35 pm ] |
If the fluid was fresh when installed and then changed around every year there after, I'd expect 10 years +. If however, the routine service is overlooked, then as little as a couple of years. Remember that Brake Fluid is hydroscopic and so will absorb moisture. <EDIT> Mind you, many years ago there were some cheap ones getting about that leaked within days of being fitted. Rubbish seals on them. |
Author: | drmini in aust [ Fri Mar 18, 2011 8:34 pm ] |
I had 2 `Brake Equipment' 5/8 rear ones leak recently, 6 months apart but each 12 months old- were OK after I fitted new seals to em. |
